DesmoDue Parts For Sale & Wanted
This section is for all your DesmoDue race parts, accessories and the like.
Old 21-Apr-2013, 22:46   #1
Bimjob Bimjob is offline
Bikes: Yamaha R1, Ducati 600SS
Wanted 600ss Tank
Has anyone got a 600ss tank or any tank that will fit my 600ss?
Old 22-Apr-2013, 09:07   #2
Tom Roberts Tom Roberts is offline
600ss Tank
I have a tank, red, no internals very slight gravel rash, £50 plus p+p.
Regards
Tom
Old 23-Apr-2013, 12:28   #3
Regards
Tom
Cheers Tom, how much for the p+p and where are you?
Old 24-Apr-2013, 07:47   #4
SS Tank
I'm in Ruthin, North Wales about an hour away from Oulton Park.
I have a job that takes me all over the country, where are you ?
Postage could be expensive .....
Tom
Old 24-Apr-2013, 09:42   #5
Tom
Cheers Tom, I'm in Lincoln but on reflection I need a tank with all the internals as I need it to be a spare ready to fit post crash trackside
Old 24-Apr-2013, 10:49   #6
Rubbish, you can swap the pump over in less than 15 minutes or just use an external pump and filter, which is what I used on my 583 and still do on the 620.
Old 24-Apr-2013, 18:22   #7
As I found last saturday, I wont always have 15mins available. In an ideal world I could do with a complete tank ready to fit. In an ideal world I could do with not crashing!. Out of interest Phil, do you need some sort of sealant to fit the wiring connector to the base of the tank?
I heard that some people have had problems with external pumps but I take it youve had no bother?
Old 24-Apr-2013, 22:52   #8
No probs Jim the 620 uses a generic vehicle high pressure pump. I did have some probs early on with my 583 with a sealant in the alum tank coming delaminated and causing blockages. But always ran with external pump and external filter.
The wiring to the pump is sealed into the tank with a tube nut and a distorting rubber gland.
Also a benefit of an external pump is you can have a lot less fuel in the tank. A standard SS requires 3 litres before it picks up any fuel. So you are looking at 5 litres plus race distance.
With external you can get this down to 2 litres plus race distance.
Old 24-Apr-2013, 23:38   #9
coppersaucepipe coppersaucepipe is offline
Bikes: YZF750R, DD 'B' class monster #2
Why does the SS need a pump at all? What's wrong with gravity?
Old 25-Apr-2013, 08:50   #10
The internal pipe work does not cater for a gravity feed, it may work with a modified tank. Also you would need a fair amount of fuel to provide a head pressure, which isn't condusive to a race bike.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:50.
