Old 23-Jul-2005, 21:49   #1
phil_h phil_h is offline
phil_h's Avatar
power commander question
The power commander map downloads refer to :
502='termi full exhaust with std filters', 503='termi slip-ons', 504='termi 45 open half system', 505='termi 50 open half system', 507='termi full with std or a/m filter'.
My 748sps has 45mm downpipes, 50mm 'rear' pipes and 50mm termis and carbon tubes with a one foam filter which covers both intakes.
Which one is it ?
Old 24-Jul-2005, 02:24   #2
DEMON DEMON is offline
DEMON's Avatar
Mood: on the back wheel !!
Phil
you can try the 504, as your headers are 45 mm, or go for the 507 depending on your air filter arrangement.
I spoke to a guy in Aussie recently regarding the 748, and it is important to keep the headrers at 45mm, dont go up to 50mm, as you will lose power.
Its best that you do a dyno run, or road test with a data logger, to see how she runs.
I found that you may have to make minor changes to some parts of the maps too. Check your PC has the firmware upgrade which allows you to trim each cylinder, thus allowing you to fine tune for the difference in the operating temps of the two cylinders (rear runs hotter).
I suggest that if you dont have the required equipment to test your setup, that you pay for a proff to do the job, maybe a ducati biased one.
I can recommend John Hacket, he lives the bikes and has mountains of experience. Me I did it myself as I have the equipment, but I live in Newcastle, too far from you.
By the sound of the air filter arrangement you describe, it sounds like an ITG type of setup, or some other aftermarket filter, so try the 507 first and see how you get on.
hope this helps.
Old 24-Jul-2005, 13:21   #3
phil_h's Avatar
Thanks mate
it doesnt help when the descriptions are obviously abbreviated.
My first objective is to get rid of the hole in the power delivery at 5-6k which the current setup has, as I prefer riding on the throttle to changing gear to hunt the power.
Unlike many people, I'm not overly bothered what my top-end bhp is so long as it makes 80 to 100, I'm happier than with the 110-odd from a 916 etc.
Having said that, it would be really nice to ride a biposto and an R back-2-back to feel the difference.
Old 24-Jul-2005, 18:32   #4
Jamcoly Jamcoly is offline
Jamcoly's Avatar
Mood: starting to feel better
i've riden an R
set up for drag racing
now there is a difference
no bottom end
a little mid range
then loads of top end
+more on top
and they ride so nice too
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:57.
