Old 27-Jul-2005, 20:56   #1
Harv748 Harv748 is offline
Harv748's Avatar
Re laquering carbon...best way?
Some of the carbon on the 'ol SP is starting to look a bit milky and marked after 10 years...so was thinking about re-laquering it.
Anyone done this. Is it as straight forward as it sounds...rub it down a bit with some wet and dry and then apply a few coats of clear laquer as with paint?
Thought I would ask first before fooking things up!
Old 27-Jul-2005, 21:00   #2
Mood: Come on spring!!!
carbon
Have a word with Neil748r he refurbed my caron airtubes to a superb condition!! i think its gellcoat on them and not laquer! Not sure on that tho!
Old 27-Jul-2005, 21:08   #3
Sandbar Sandbar is offline
Yes!!!
Or replace with new parts
Sandbar
http://www.sandbarcomposites.co.uk.
Old 27-Jul-2005, 21:13   #4
Harv748's Avatar
...but what about the parts that have gone a bit milky in colour...that looks quite deep and I'm guessing could go all the way down to the carbon.
Will it dissapear if it is given a freah coat over the top do you think?
Old 27-Jul-2005, 22:27   #5
keefer keefer is offline
keefer's Avatar
I did my air tubes.
just sand them down with fine wet and dry as if you are getting them ready for a final coat. then lacquer.
you can see when they are wet while sanding whether the milky effect has gone
Old 28-Jul-2005, 00:49   #6
If the milky effect has gone all the way into the carbon fibre then you are stuck with it. If you sand it away then you are also sanding away the carbon and it will be a helluva mess.
Unfortunately you won't find out until you have tried.
Which parts are you talking about?
Are you costing your time (labour) at zero?
Sandbar
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:38.
