Old 28-Jul-2005, 03:00   #1
marchesini marchesini is offline
Project S4R - the point of no return (part 4)
This is a long winded update on my Monster S4R Project 'Changeeveryfink' . I haven't posted here before as I (wrongly) assumed that most Monster owners read the UKMOC forum. So grab yourself a (strong) black coffee and settle down - there's a lotta rubbish comin' your way.......
It's been 6 weeks since it last ran at Mallory where it survived the trip with very few problems. The detailing part has taken longer than expected but we now have (or have on order) all the parts needed to complete the job. I have also come to the realisation that this bike will never be returned to stock - the initial plan was that if I ever wanted to sell the bike, the original parts would go back on and I would sell the trick bits separately. The project has now taken a life of it's own and when the angle grinder came out last week, I resigned myself that this is pretty much a one-way journey.
EXHAUSTS
They were fitted for Mallory and but we were not happy with the positioning of the pipes. Granted, the pipes are made to work with the existing tail but with our tail chop, the cans just extended too far past the frame. There was no other choice, the angle grinder had to make an appearance.
Due to the slightly flared ends on the carbon, the cans were not able to be shortened. We then held the cans into the preferred position and worked out the cuts. The MV seat unit sits quite high on the frame so wanted the cans to sit parallel and fill the space under the seat. All pretty straightforward but with the new can position, the seat lock was obscured. It was at this point, that "Feck it, just do it" was uttered for the 100th time and off came more of the frame and along with it, the seat lock. This was when I realised, I was at the point of no return - although Dave and Mark probably knew that months ago. I've always been a bit slow to catch on.
The pipes now seamlessly blend into the seat unit so a bit of repolishing and they will be back on the bike.
In hindsight, the Ducati Performance kit (filter, chip cans and link pipes) was a bit of a waste of money. The DP ECU is to be replaced by the FIM unit and the pipework have been cut about so much, it would have made much more sense to buy some shorter end cans and fabricated the pipework. In fact, the filter is the only part of the kit used in it's original form - it must be the most expensive filter in history.
DASH REPLACEMENT
An extensive search led us to the door of FIM (Fuel In Moto), an Australian tuning house, who make programmable replacement ECU's. There is very little wrong with the bikes fuelling as it stands but the replacing of the original clocks opened up a can of worms due to the built in immobiliser. After speaking to Ducati UK, John Hackett and Sigma Performance, none of them could guarantee anything that could bypass the immobiliser on the factory dash. This really strikes me as being slightly strange being that a large part of Ducati's image is linked back to it's racing heritage. Why they would make bikes that are have immobilisers that are nigh on impossible to bypass is beyond me. Yes, I know that is the point of any security system but if you wanted to race an S4R (unlikely, I know) or a Monster 620ie (reality in the DesmoDue series), then there 'should' be a relatively simple way to remove the speedo.
As it transpires, FIM have developed a replacement computer - the Ultimap U59. The main benefit of this unit is the ability to bypass the immobiliser which in turn allows us to fit an alternative dash. It is also fully mappable for fuel, rear cylinder correction, spark and the rev limiter - this allows us to increase the rev limit so it's on a par with the 996 bikes.
This, of course is all in theory. The chip and dash will be arriving within the next week so we will soon find out either way.
SEAT UNIT
This has been painted and fits nicely over the existing Monster seat. The indicators have been modified so that the lenses are now clear with the indicators set further inside the seat. The result is a much brighter turn signal which of course will be handy on it's next track day outing - I found it a bit difficult trying to get my knee down and doing hand turn signals at the same time. . The other small mod is a one-piece lighting connector so that the original seat and the MV seat can be swapped if ever the need arises.
The seat will be recovered in Alcantara if we can find a close enough red to match the Candy Red paintwork. Vinyl may be used as a second option as it has a wider range of colours but will also be much cheaper - alcantara is £70.00 per meter!
STEERING DAMPER
This proved to be quite complex. The S4R damper only works with the handle bar mount so thought that using the S4 clip-ons kit would prove to be a closer fit. Dave could only get this to work by using parts from each kit which would then be extremely expensive and then leave a steering damper kit which was next to useless. The S4 kit option wasn't close enough so Dave went back into the workshop and fabricated another damper bracket. The set-up now looks much tidier and more importantly, the four handlebar mounting holes will all be re-used rather than looking like something is missing.
RADIATOR
The radiator has been removed to be painted black. On the S4s, it was black but on the S4R it was changed to silver. I don't think that anyone has ever thought that the radiator was one of the nicer parts of the bike so why Ducati chose to make a feature of it on the newer bike, I don't know. The fans and carbon side panels are black so we decided the bulk of the radiator would be lessened somewhat by being darker.
While the rad was off the bike, it is amazing how much better and slimmer the bike looks - much more of an improvement than I expected. This in turn got us thinking (again) and are now looking into making a slimmer and longer radiator that would be much more discrete - perhaps double thickness but not nearly as wide yet would still have the same mass as the original.
OTHER BITS
The correct quickshifter has been installed and the Ohlins remote adjusters have been repositioned for the third (and probably not the last) time. The removal if all the rubber frame ties mean that the we can't just run additional wires all over the bike as it would undo all the earlier work of cleaning up the lines.
The mirror mounts have arrived from the US and I have also managed to source some 996 switchgear and throttle assemblies. The clip-ons meant that a lot of the original switchgear wouldn't fit to the bars. The fast idle switch is now on the throttle and the LH switches have been replaced by 996 items.
The main hold-up now are the imminent arrivals of the FIM U59 chip and the Translogic dash. The dash will alloow us to finalise the front end - the brackets for the headlight, indicators etc. The chip to see if the clocks can be removed and being able to get the bike to run. The bike is slowly taking shape and hope to see it on the road (all being well) by the mid-end of August. Fingers crossed.
Laters all
simon
PS. I can't work out how (if it is possible) to attach more than one pic at a time so more pics are available here:
http://www.simonvicki.co.uk/wheels_p...r_stage_6.html
[Edited on 28-7-2005 by marchesini]
Old 28-Jul-2005, 03:16   #2
side view
Old 28-Jul-2005, 03:18   #3
rear view
Old 28-Jul-2005, 04:08   #4
Festa748 Festa748 is offline
Festa748's Avatar
Stunning bike
Where you get the carbon cam covers and water pump cover from in carbon??
Old 28-Jul-2005, 04:23   #5
Originally posted by Festa748
Stunning bike
Cambelt covers were already on the bike and the water pump cover was from Spareshack (IIRC). I think they are doing a clearance on loads of items so it might be worth a (virtual) visit.
http://www.ukmonster.co.uk/monster/s...ad.php?t=13512
HTH
laters simon
Old 28-Jul-2005, 13:12   #6
That's a seriously nice bike, can't imagine the time and more so money you've spent on that.
Old 28-Jul-2005, 13:26   #7
Mark Mark is offline
Mark's Avatar
Wow, I love the frame colour. Those wheels are a nice touch as well.
Old 28-Jul-2005, 14:09   #8
Felix Felix is offline
I completely agree with you about the radiator. It's one of the bike's least appealing feature. A good friend of mine has a S4R as well and we've contemplated having a custom rad fabricated more than once. So far, he hasn't taken the plunge. A good design for a slimmer radiator would be a great feature. I'd be very interested where you end up on this.
Old 28-Jul-2005, 17:03   #9
Radial brembo's on ohlins forks .... where's the drool smiley?
Old 29-Jul-2005, 03:22   #10
I am looking into this and JHP were looking into doing some slimmer rads - haven't heard anything for a while though.
I think that the width could come in by 1.5-2 inches either side and the thickness could be increased. This would make the rad be in line with the rest of the frame without sticking out either side. I guess that running either one fan or two smaller fans would sort the cooling.
I was also posted a few other options to recover the capacity. Increase the water flow (speedymoto pump). And increase the system pressure and use evans coolant.
I also think that just by painting it black, it will lesssen the optical bulk of it. Mine has been painted just as a short term fix until we can look at the rad seriously - I need to let my fingers do the walking and find 'the radman'. Anyone recommend anyone?
Laters
simon
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:18.
