Old 27-Jul-2003, 11:49   #1
SSTU SSTU is offline
Heavy Clutch
Some people seem to have problems with there clutch ie very hard to pull the lever.
I my self and richr do not have this problem and I think if your clutch is heavy there is something wrong and it may need attention.
Old 28-Jul-2003, 08:20   #2
psychlist's Avatar
Mood: Lucky? For some, maybe!
Huh!?!
Go on then, like what!
Old 28-Jul-2003, 09:05   #3
Colin900SSFE Colin900SSFE is offline
Mood: Looking forwards...........
Yup, like I am wondering where the first post has gone with the a reply up top
Old 02-Aug-2003, 11:32   #4
I dont know I am not a mechanic I was merly making an observation that not all ss have a clutch problem.
Just as a sugestion. Have you tride comletly draning the fluid and bleeding the line from scratch?
Is the correct grade of fluid installed?
Old 02-Aug-2003, 17:25   #5
psychlist's Avatar
Not a problem I \'ve come across SSTU?
I know plenty of people complain about Duke clutches being very heavy (only in comparison to Jap bikes) and if you cant get used to it then it can be sorted by changing to a bigger master cylinder. Changing old fluid wont help with the "heaviness", but will stop your clutch feeling worn out. Old fluid (with air absorbed into it) will compress itself rather than transmit the pressure to the clutch operating lever so you wont get as much push on the clutch mechanism as your pull on the lever. Cheers for the thought though.
What I would like to know is why has my clutch fluid gradualy gone black!?!
Old 02-Aug-2003, 19:37   #6
Rushjob Rushjob is offline
Rushjob's Avatar
Mood: :-)
They all do that Sir
Old 03-Aug-2003, 00:06   #7
Murray Mint's Avatar
Yep they sure do, strange one aint it.
Old 03-Aug-2003, 22:08   #8
psychlist's Avatar
But why?
Old 03-Aug-2003, 22:53   #9
andy900 andy900 is offline
i think it is because a certain amout of crap can seep through the seal on the master cylinder which is known to be a bit poor, i have a yoyodyne mastercylinder on mine and my fluid is as clear as a bell all of the time
Old 08-Aug-2003, 21:51   #10
Maybe the fluid is picking up colour from the rubber in the hoses!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:09.
