Old 30-Jul-2005, 19:52   #1
kev3 kev3 is offline
748 Swing arm spindle
Hi everybody,
I,m having a problem removing my swing arm spindle so I thought I'd register here and ask the experts.
According to the Haynes manual you should undo the bolt from the right hand side and 'withdraw' the spindle from the left.
No problem removing the bolt but the spindle is stuck solid, it will rotate with a 14mm allen key in the left hand end but it seems to be spinning the collars that locate the swing arm in the frame with it. I assume it's somehow rusted/ welded itself to these collars.
I've supported the weight of the engine from below,bathed the spindle/ collars in WD40 put the bolt half way back in and given it a belt with the hammer but it's not moving. I dont want to hit it too hard and damage the threads but there doesn't seem to be another way to drift it out.
Am I missing something??? any help would be appreciated.
Kev
Old 31-Jul-2005, 00:05   #2
http://ducatisportingclub.com/xmb/vi...1522#pid202926
Old 01-Aug-2005, 01:24   #3
Brute force method unfortunately didn't work, results were damage to the spindle, a 14mm deep socket,extension bar and the knuckles of my left hand but the damned thing is still stuck fast.
It may have to be drilled out, any more tips before I take the black and decker to it?
Kev
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:49.
