Old 01-Aug-2005, 12:31   #1
748IOM 748IOM is offline
Mood: Yellow!!
Clutch Spring Bolt Size
Following on from a previous thread, I have a stripped bolt on one of the springs for the pressure plate of my clutch.
Does anyone know what the spec of these bolts are so I can source a replacement?
Old 01-Aug-2005, 12:41   #2
Harv748 Harv748 is offline
Harv748's Avatar
Are you sure its the bolt...isn't it usually the hole thread that gets buggered?
Old 01-Aug-2005, 12:42   #3
Dibble
call Nelly at Cornerspeed on 01623 758877, he probably has a few laying round, it may be worth getting a set of stainless steel bolts, springs and caps as they are not as soft as the original bits ...
Old 01-Aug-2005, 12:44   #4
748mart 748mart is offline
If you u2u me you address i'll stick one in the post for you.
Old 01-Aug-2005, 12:56   #5
Mood: Yellow!!
Yes its the bolt head thats buggered, I will be replacing all with stainless but for now I just want to get the clutch plates cleaned, so before I drill out the old bolt I just want to get another to replace it with so I can still ride it after cleaning out the clutch.
I'll see how I get on today, my ducati dealer "may" have one in yet just thought I'd see if there was a size available aftermarket that I could get from an industrial supplier over here.
As I'm using the bike as transport its not like I can take one with me as an example.
748mart, thanks for the offer, very generous. I'll see how I get on today.
Old 01-Aug-2005, 13:38   #6
FiscusFish's Avatar
The thread will be M6 and the length is around 20-25mm (measure the length of one of the others). There's nothing special about them. You should be able to buy one anywhere.
Old 01-Aug-2005, 14:01   #7
Nelly has stainless ones. No need for stainless springs or caps unless you are running an open cover.
Old 01-Aug-2005, 14:05   #8
Dibble
they come in a kit though, might as well do it properly ... lol
Old 01-Aug-2005, 14:20   #9
They are M5 (5mm) thread and about 25mm long from what I recall, you need a 4mm Allen key to fit them
Old 01-Aug-2005, 16:10   #10
Yep. M5 x 20mm I think. 25mm should be fine though, but definately M5
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:03.
