Old 02-Aug-2005, 12:12   #1
Lee1980 Lee1980 is offline
Bikes: Xdaivel
Lee1980's Avatar
Mood: Xdiavel..awesome!!
S4r low speed throttle response
Since my 600 mile service i have been getting some weird throttle action, at first it seemed to tight so lubed the cable and greased bits where the cable runs was bit better then.
To try and describe is hard but ill give it a go, i have the throttle open slitghtly at low revs constant, then it seems to move as if it is slipping or something, like sliding past something but not actuating the fuel injection.
I have booked into dealer but its not till the end of the month and they said some sort of ptfe lube is used that is dry, how would it lube then
I have also losened the throttle cable to give more freeplay a bit better but still does the weird slipping thing
Old 02-Aug-2005, 12:21   #2
Rushjob Rushjob is offline
Rushjob's Avatar
Mood: :-)
Dry "lubricants" are used in several situatuions.....
Talcum powder when getting a wet suit on...Graphite in dusty environments.....
Some oil based lubricants cause the nylonlining of thecableto swell,gripping the cable &doing the opposite ofwhat youwant.
Most cables these dayswere PTFE lined I thought, thus negating the need for lubrication.
Old 02-Aug-2005, 13:30   #3
Bikes: Xdaivel
Lee1980's Avatar
Thanks Rush job,
Interesting since lubing and greasing mine though its better now, and the guy at dealer never said it was bad to lube it, so hope i not made it worse
Just the wierd slipping thing still going on, maybe to do with cable routing or something.
Old 02-Aug-2005, 20:16   #4
Nattyboy Nattyboy is offline
Nattyboy's Avatar
Mood: Back down to 3 :>(
Its coz you ride it like a girl Lee and its all gunked up...
Fancy an isle of wight jaunt the weekend (sunday) mate...? Riding down from swindon to meet a shed load of UKMOCers at the ferryport for about 9.30..
Cheeeeeeeeers
Nat
Old 03-Aug-2005, 01:02   #5
Bikes: Xdaivel
Lee1980's Avatar
Cheeky Nat, I been opening it up to now
Its better now i adjusted the cable more free play was to tight before ill see how it goes
Have to see if im off out sat night but sounds gd Nat
I'll mail u in work tomoz if thas ok.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:19.
