Old 03-Aug-2005, 09:28   #1
Gareth Gareth is offline
Front fender Removal
I have just ordered the Corse stripe from Carbon Trader. Notice that I need to remove the front "fender" to be able to fit it properly. Tried this with the wheel in place and there does not seem to be any way of getting it round the forks. Is the only way to take out the front wheel and drop the "fender" out or is there some way to doing with with the wheel in place?
Had a go at fitting the strip with the fender still on the bike, but whilst I got the front looking perfect, it all went nasty when I couldn't get a proper grip around the forks. Fortunately I have enough tape left for another go !
Old 03-Aug-2005, 12:32   #2
khu996 khu996 is offline
khu996's Avatar
Apparently, you can twist the fender out of place with the wheel still on, but when I tried it, I scratched it pretty bad! The only sure fire way is to remove the wheel...a pain I know, perhaps a design fault?
Old 03-Aug-2005, 18:05   #3
chris999 chris999 is offline
Mood: red and proud !!!!
if its the standard fender you can manipulate it out ( i put a duster either side to stop scratching on either fork)
but you can do it...
if its a carbon etc you are looking discs and wheel removal...
Old 03-Aug-2005, 18:56   #4
Yep,twisted mine out,no problemo.
Carbon one slipped back in a treat!
Old 03-Aug-2005, 20:42   #5
Thanks...looks like another attempt is needed at the weekend !!
Old 03-Aug-2005, 22:08   #6
Carbon749's Avatar
Mood: I own a flame thrower
Rip up sheets, boil water and send the kids out cause there will be swearing ..... but, Twist and pull method will work
