Old 04-Aug-2005, 09:33   #1
centurysup centurysup is offline
Steering damper
Just noticed that the (standard) steering damper on my 998 is rubbing against the tank. While it's not taken any paint off the tank, it is marking it.
Anyone else come across this and, if so, how did you fix it?
Cheers.
[Edited on 4-8-2005 by centurysup]
Old 04-Aug-2005, 11:54   #2
m1keyp m1keyp is offline
Have you (or someone else) rem,oved the damper?
If so it may ahave had the mount reffited wrongly.
Old 04-Aug-2005, 12:12   #3
Me do anything mechanical to the bike? No way Mikey.
I've had the bike from new and as far as I know the damper's never been removed. Not sure how long it's been doing this for but I only noticed it fairly recently.
Old 04-Aug-2005, 12:27   #4
dave996 dave996 is offline
dave996's Avatar
Mood: Fed up...
Can you take a pic from the top so we can see please
Old 04-Aug-2005, 12:36   #5
neil748r neil748r is offline
There's a little rubber "O" ring under the damper mount. These degrade over time which allows too much movement of the rose joint in the damper mount - result, the damper falls back against the tank.
Old 04-Aug-2005, 13:01   #6
Cheers Neil, that sounds like exactly what's happened. It's going into the workshop today anyway to get some bling fitted so I'll get them to check it while it's in.
Old 04-Aug-2005, 13:11   #7
Not the local dealer begining with "A" hopefully?
Old 04-Aug-2005, 14:21   #8
You have a U2U Neil.
Old 06-Aug-2005, 13:43   #9
Fixed. Neil, your suggestion was spot on.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 13:22.
