Old 07-Aug-2005, 19:18   #1
deej deej is offline
deej's Avatar
748 racing topend
will a racing top end fit onto my standard 748 bottom end, i expect a few of you have seen it on ebay for sale it was from dan ankers 748rs
will it need any extra servicing work if fitted and what extra work would be required to fit, any info welcome
im not a technical expert just looking for that little bit of extra power to keep up with my mates cbr's and sp2's
cheers
deej
Old 07-Aug-2005, 19:45   #2
748IOM 748IOM is offline
Mood: Yellow!!
Consider an 853 upgrade?
http://www.sigmaperformance.com/748-853.html
Old 09-Aug-2005, 13:50   #3
Mr_S Mr_S is offline
Depends what year the RS is, and what year yours is as to whether it's bolt directly on, but I doubt they'd fit straight on as the RS is a later engine than the one you have.
You'd also want the HiComp R / SP pistons in there as well and a complete re-map to account for the larger valves / cams
Oh, and you should have the cams dialled in as well.
Give Nelly at Cornerspeed, or Steve at MotoRapido a call and see what they say.
Old 10-Aug-2005, 00:31   #4
deej's Avatar
think it could be the 853 kit money depending
if the wife gets the job shes going for it will defiently be the 853 kit !!!
Old 10-Aug-2005, 22:51   #5
Ducati Dealer
wilf's Avatar
Wotcha,
The main problem will be the injectors wont fit without having the heads machined, the R and RS heads have a step to space the injectors together and the bp or sps ones wont go on (nor will the inlet rubbers)
The other point is that although the 748RS cams are mega, but they are VERY hard on valves/collets/rockers and belts.
The RS cams make much more power but only at high revs , 8k+, this feels great to ride but will make you want to keep the revs hanging on in each gear and you will find the rev limiter feels lower! this is not a good idea on the standard conrods and crank.
your service bill WILL go up. RS cams and valves are designed to be replaced every 700 - 1000 kilometers.
The best option is without doubt an 853 kit with hi compression pistons, SP cams (if you can find some) and an adjustable chip. 916 power and 748 pick up and revs.
good luck.
Old 10-Aug-2005, 23:45   #6
Hello chap, 'bout time you signed up and started posting.
Old 10-Aug-2005, 23:55   #7
Ducati Dealer
wilf's Avatar
wotcha matey,
try to keep a low profile here, but just sent my £25 and joined up so thought i'd chip in! full of advice me!
and want to come an play on track days with you guys, need the track time!
Old 10-Aug-2005, 23:57   #8
keefer keefer is offline
keefer's Avatar
ha ha hope not.
I've seen that vid at cadwell where you tried taking out that pore slow person up the inside
Old 10-Aug-2005, 23:58   #9
cool, Brands Indy's the next one, but I'm not going
Got to pick up her ladyship and the little one from the airport that day....
Old 10-Aug-2005, 23:58   #10
wotcha matey,
Welcome Wilf - you may as well get behind the bar and get serving then
Double whiskey thanks chap
And one question (call it ignorance, I'm going to play the Australian ignorance card) but what's all this 'wotcha' stuff?
