Old 09-Aug-2005, 11:51   #1
Twinfan Twinfan is offline
Twinfan's Avatar
Fitting rearsets - threadlock required?
As the title says really. I'm getting my bike back tomorrow and I've got some rearsets to fit. I think I need some threadlock on the bolts? If so, what type?
Does anyone know the torque settings I need to use?
Cheers!
Old 09-Aug-2005, 13:19   #2
Never does any harm. General purpose Loctite from Halfords will do fine.
Torque wise, normal torque figures for bolts are 6mm thread 10Nm, 8mm are 19Nm.
From experience, if you're fitting Gilles, do every bolt with thread lock, including the preassembled ones. They seem to fall out on their own after a few miles
Old 09-Aug-2005, 13:38   #3
Twinfan's Avatar
Cheers Nelly - much appreciated. They aren't Gilles ones, but I'll follow your advice anyway!
I'll do them and the pressure plate/clutch cover tomorrow night
Old 09-Aug-2005, 13:45   #4
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
TF,
I try to use an assembly locite. More of an anti vibration cure than a 100% hard fit. The benifit of the assembly version is that it's shiftable if you need 'em off. The hard fit version need a good heating to soften off. World of pain at times.
Rgds, Rob
Old 09-Aug-2005, 14:27   #5
Twinfan's Avatar
Cheers - I wasn't going to go for the permanent version. I think they're colour coded according to strength? I'll get the non-permanent version from Halfords.
Old 09-Aug-2005, 16:07   #6
duck duck is offline
duck's Avatar
green is high strength anti vibration and blue is medium strength
Old 09-Aug-2005, 17:57   #7
Mr_S Mr_S is offline
Loctite 243
I did use 222, but had to keep re doing them, so stepped up to the stronger stuff.
Make sure you clean the threads first, otherwise it just bonds to the cr@p in the thread instead.
Old 09-Aug-2005, 18:06   #8
Mood: Diet
the original bolts are the soft cheese version, i rounded the *******s getting them out in the first place, so if you are going to loctite them you may want to invest in some better bolts, i got mine from nelly
Old 09-Aug-2005, 18:07   #9
Twinfan's Avatar
Cheers - I'll see how I get on...
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:38.
