Old 10-Aug-2005, 10:44   #1
ttstu ttstu is offline
Mood: On the mend!
Chip Removel
Is this really a slot out slot in job? Is ther anything I should be aware of? Will the bike start afterwards?
Old 10-Aug-2005, 12:52   #2
Mood: me in a mood? NEVER!
what on?? dont think you can on the 749 or 999 but I have been known to be wrong. easy on the 748 916 etc just be carefull not to bend the pins when pushing the chip in.
Old 10-Aug-2005, 13:14   #3
bolds bolds is offline
When you change the cpu on 749/999 you have to remove all the battery box and components -all the wiring is very tight so its a bit of a fiddle -also when cpu is unplugged the throttle position sensor has to be reset and thats a dealer only job with diagnostic kit
Old 10-Aug-2005, 14:02   #4
Mood: going for a ride...
bollox
...........but you are right about where it is and how to get it out
Old 10-Aug-2005, 20:26   #5
Mood: On the mend!
So once I've stripped down have the bike it's just a swap job and she should start?
Old 10-Aug-2005, 21:21   #6
nathanhu nathanhu is offline
nathanhu's Avatar
Mood: head down
yep but dont use the red key..........
Old 10-Aug-2005, 22:50   #7
bollox
Quote from workshop manual " When changing the throttle body,and or the throttle position sensor,or the engine control unit,or the section of wiring connecting these parts,it is necessary to carry out a new TPS reset procedure"
Old 11-Aug-2005, 09:18   #8
ah well , my old 999S , the wifes 749S and my current 749R must not have read the workshop manual then , all 3 have had the CPU off and swapped for a race CPU and swapped back again with no problems
Old 13-Aug-2005, 13:13   #9
Mood: On the mend!
Well fingers crossed then.
Old 13-Aug-2005, 21:35   #10
gimpboy450 gimpboy450 is offline
gimpboy450's Avatar
Mood: crank it and bank it
chip removal
to carry out a new TPS reset procedure'
How do you perform this TPS reset??/
