Old 10-Aug-2005, 12:57   #1
cl0nd0n cl0nd0n is offline
cl0nd0n's Avatar
Quick Release Fuel Lines
Hi guys
I am sure this may have come up before so sorry in advance.
Can anyone tell me the best and cheapest way to fit quick release connectors to the tank on my 748. Currently it has the standard banjo style fittings and is a right old pain trying to balance the tank in one hand without scratching it up while screwing the pipes on!
thanks
Old 10-Aug-2005, 13:27   #2
Mr_S Mr_S is offline
They should be quick release as standard.
QR connection goes straight into the pump under the tank.
Old 10-Aug-2005, 13:37   #3
Older and E models don't have quick release lines, as you now know.
you should be able to purchase the quick release parts from your Ducati dealer, but I think you'll need a different pump for the tank as the quick release is integrated into there.
How about fitting your own quick release connections into the current lines? Demon-Tweeks sell them for £20 for a single sided connector (which is all you need) and buying two of these is cheaper than a new pump and fittings.
Old 10-Aug-2005, 14:00   #4
cl0nd0n's Avatar
Your right guys. This is an E model which for some reason did not come with the quick release.
Do you think it would be ok to fit them in mid line? Just worried about leaks! I'm not one for getting blown up whilst riding!
The aim is to make it easy for removal as I am aiming to rebuild this particular bike as a GP style track bike.
Cheers for the help!
Old 10-Aug-2005, 14:41   #5
As long as you fit them to the hose correctly you'll not have any leak problems. Splice the hose neatly then use fuel line clamps or Jubilee clips to fit the connectors.
You'd need to mark them up in such a way that you always connect them back up correctly though.
antony,
How old does a 748 need to be before you don't get QR's? Must have only been the '95 run.
Old 10-Aug-2005, 14:53   #6
Chris,
These are the sort of things you want
http://www.pro-streetcycles.com/acat..._Coupling.html
http://www.wunderlich.co.uk/shop/ero... 57CcountryGB
Old 10-Aug-2005, 15:41   #7
This is Ducati we're talking about - there are no rules!
Its a bit like the Dzus fasteners on the fairing - some early bikes came without the d-rings while some did. The race sp/sps ones certainly should have, while the bipostos shouldn't. The later E models shouldn't have, but the S and R bikes did.
However, you'll find that some dealers ended up with bikes that had them when they shouldn't because Ducati ran out on a friday afternoon, so they just grabbed a handful from the d-ring tray instead to get the bike finished.
It's a bit like the forks and shocks - some got Ohlins over Showas for whatever reason.
Ducati have various periods of cost cutting and it must be that the fuel pump lines was another exercise in this. I know that the S and R model bikes definitely should have them, but that it's probably hit'n'miss if you get them on an E model. Remember that they switch from biposto/sp/sps to E/S/R in 2000.
Old 10-Aug-2005, 16:02   #8
and I have a '97 bip with them
Which is where the assumption that all the range had them, since mine started out as the base spec.
Old 10-Aug-2005, 17:06   #9
cl0nd0n's Avatar
Weird! Mine is a '00 E & i'm without!
Ducati confuse the hell out of me!
Thanks for all your help with this one guys!
Old 10-Aug-2005, 17:24   #10
E for economy version, save a few quid by leaving out QR connectors adjustable headstock, big bottom yokes and what ever else
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:40.
