General Motorcycles only
Old 13-Aug-2005, 15:27   #1
Paul357 Paul357 is offline
Bikes: ducati 853 (was 748 sp)
Paul357's Avatar
Mood: 853 big bore done by steve and co at motorapido. Sipper clutch, ohlins rear shock and lots of carbon
FUEL PUMP WONT SHUT UP
Could any one help. Went out yesterday and my bike cut out and now will not start. When turning on the ingnition the fuel pump runs continuously. I know it should prim and then shut off but it doesnt. I've took the pump off and checked the fuel filter and pipes for any blockages and none found. I've removed every snap connector I could find, cleaned them and given them a spay with WDf but still no joy. Is this a problem with the pump or something more serious like the ECU?
Old 13-Aug-2005, 15:48   #2
GsxrAge GsxrAge is offline
GsxrAge's Avatar
What bike mate ?
if it 916/996/or 748 it could be the chip in ecu.
I fitted a chip once and pump would run and would not stop and bike would not start!
Put another chip in all ok.
But you have to work out why it cut out and spiked the chip ?
Old 13-Aug-2005, 15:56   #3
bike mad bike mad is offline
bike mad's Avatar
did you pressure test the pipes ?
Old 13-Aug-2005, 17:38   #4
Paul357's Avatar
Hi guys thanks for the gen. The bike is a 1995 748 SP. I did try the origional chip but the problem was still there. No I havnt pressure tested the pipes. How can I do this?
Old 13-Aug-2005, 17:54   #5
As a safety feature, the computer is designed to shut off the pump anytime it doesn't get a signal that the engine is running. Your problem could be something as simple as a poor connection to the RPM sensor. I'd first try disconnecting-connecting the harness connector to the computer to clean the connection pins, but it sounds like you've done that. Use electrical contact cleaner if necessary, but avoid using WD40, it leaves an oil residue.
The next step would be to swap the computer with one that you know is functioning.
[Edited on 8-13-2005 by Shazaam!]
Old 13-Aug-2005, 22:41   #6
748mart 748mart is offline
Could be the fuel pump relay stuck on, the relay is one of the 2 large relays under the seat.
Old 13-Aug-2005, 22:42   #7
MarkyMark76 MarkyMark76 is offline
Mood: .
I had a very similair thing when i refitted my standard termis and original chip to my 748s. Fuel pump would not shut off. Replacing the chip fixed it. Does the bike turnover? Mine did and there as a real smell of petrol, seems at least one of the injectors was open, no pressure was built up before ingnition and hence the pump kept running. Probably not much help... Good luck.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 03:49.
