Old 13-Aug-2005, 18:55   #1
deej deej is offline
deej's Avatar
trackday bike advice
im planning on removing my mirrors from my bike when i do silverstone in 2 weeks but what can i use to keep the nosecone attached to the framework, will a normal nut and bolt do ???
i will remove the rear indicators and number plate hanger and tape up the front lights but what else do i/should i do to my bike
cheers
deej
Old 13-Aug-2005, 18:58   #2
pair of plastic numberplate nut and bolts.................
Old 13-Aug-2005, 19:00   #3
mogwai mogwai is offline
mogwai's Avatar
Mood: IF IN DOUBT..GET BLAGGING.
Cable ties will do the job,but if you have the time,get some pukka fasteners from pro-bolt or someone else..ring them and tell them that you've taken the mirrors off for a track day and they'll sort you out with what you require..
Old 13-Aug-2005, 21:13   #4
If you do it with cable ties, you then have to cut them to take the nose off..Unless you do it with tarmac!
Old 13-Aug-2005, 22:13   #5
doogalman's Avatar
I allways use cable-ties.
Old 13-Aug-2005, 22:21   #6
Bionicle Bionicle is offline
Bionicle's Avatar
Like this
http://www.ducatisportingclub.com/xm....php?tid=23063
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:49.
