Old 14-Aug-2005, 13:21   #1
The Big Red One The Big Red One is offline
Mood: Sparks will fly. If it keeps on
999 57mm full termignoni Edvise
Hi All if the chip or CPU has been set up for another bike can i use the same CPU on mine after it has been used on his?
Old 14-Aug-2005, 13:24   #2
nathanhu nathanhu is offline
nathanhu's Avatar
Mood: head down
if the previous owner used the red key to activate the imobiliser then its not going to work on your bike
Old 14-Aug-2005, 13:27   #3
Gizmo Gizmo is offline
Mood: is it the weekend yet??
i don't think it can be recoded.
Depending upon what you are using bike for you might get away with standard ecu, i have a 57mm system and do that. the race ecu does give an extra 1000 rpm before it hits limiter but is set up for track use so fuelling is better at higher revs. if you ride on the road you probably don't need this. The dealer who sold the system said they had done a couple of systems and the owners reverted back to standard ecu. So if that 1000 rpm isn't important it might be better to spend the money on a power commander and dyno time instead.
