Old 14-Aug-2005, 23:36   #1
aka.eric aka.eric is offline
Rectifier/Regulator mounting
The reg/rec has been replaced,bolted via bracket to the frame.No rubber mounting/well nuts----hard to the frame.This isnt standard.....is it.How should it be done correctly.
Old 15-Aug-2005, 14:40   #2
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Not sure about correctly, but mine is behind the headstock, rubber mounted on a good size piece of ally - heatsink. I have also got the multi pin connecter (alt to rec) in easy view so I can see if there's any heat damage occuring.
Rgds, Rob
[Edited on 15-8-2005 by rob41b]
