Old 15-Aug-2005, 18:16   #1
aka.eric aka.eric is offline
Couple more questions!
The rectifier was wired up:-red to + terminal battery,green - terminal battery,white not connected,two yellow to alternator.
Am I right in thinking,red should go to main fuse on battery tray,the red cable,top left in pic.
Green to - terminal battery
White to ?
Old 15-Aug-2005, 18:19   #2
Next, the conical spring in pic was on either,throttle cable or cold start cable,cant remember exactly where.Any advice please,any many thanks for the help so far.
Old 15-Aug-2005, 18:20   #3
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
From memory, that sounds right but if you check that unused female bullet connector, I think you'll find that it feeds to the main fuse/battery positive. That's where my rec' output connects.
Rgds, Rob
Old 15-Aug-2005, 18:23   #4
Rob B's Avatar
Cold start
Old 15-Aug-2005, 19:30   #5
Sorry,but exactly where.Is it between the adjuster and inner cable clamp?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:28.
