Old 15-Aug-2005, 21:38   #1
fab fab is offline
fab's Avatar
Mood: Ride with me, Ground Shaking comes as standard..
clunky clack clack neutral ?
Just movin the bike round the garage in neutral and noticed the bike makin a slight clunkety clank noise seemingly from clutch/gearbox area.
not noticed it before and am off on me euro jaunt and its given me the DPS (ducati paranoya syndrome)
Did my bike do it before, has it been the 2 missed gears at the weekend where my bike was inbetween gears then cracked one in?
Pensively yours,
Fab
Old 15-Aug-2005, 21:43   #2
chain and front sprocket. I would get a pair of vernier callipers to measure your rear wheel adjusters, make sure you have adjusted the rear wheel square when doing the chain.
Old 15-Aug-2005, 21:55   #3
fab fab is offline
fab's Avatar
as in the chain needs re adjusting?
to be honest ive not adjusted it in the 1200 miles its run in my possesion as the tension seems fine.
Old 16-Aug-2005, 10:49   #4
just a suggestion really. Im not saying the chain neds adjusting, as in tightening up. Im saying adjusting as in making sure its running true, in a straight line.
Old 16-Aug-2005, 19:52   #5
fab fab is offline
fab's Avatar
Oh right cool andyb, ill check it out
Old 19-Aug-2005, 23:03   #6
Sounds like the bike is 'not quite' in neutral.
If you are missing gears,it could be the linkage needs adjusting.Check the bolt in the adjusting rod.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:52.
