Old 18-Aug-2005, 18:51   #1
aka.eric aka.eric is offline
Couple more questions!
Where does the big plastic washer go,tried it inside the twistgrip,makes throttle too stiff.Is it right where it is,against the grip?
Old 18-Aug-2005, 18:57   #2
Fuel pressure regulator,at the bottom is an outlet for small bore pipe,just visible in pic,what does it connect to.Advice so far been really appreciated,should be quiet for a time-parts on order,the ones that are still available.
Old 18-Aug-2005, 23:10   #3
Easy one first. The pipe take off on the regulator simply vents to atmoshpere, as it is. nothing connects to it.
The plastic washer, from memory, sits betwen the throttle housing and the plastic tube the grip goes over. Not where it is, but behind the collar of the plastic tube. If it makes it tight, try some silicon spray to lube it a little.
Are you using stock grips? Renthal for instance will be grippier and the only solution may be to do away with the washer.
Old 19-Aug-2005, 12:24   #4
Thank you.
