Old 18-Aug-2005, 19:11   #1
DC DC is offline
DC's Avatar
Mood: Double 9, Single 6.
916 injectors/throttle bodies.
Hello peeps,
Quick question. Would the injectors/throttle bodies from a 916 be suitable for a 996 engine. By this I mean the bore size of the throttle bodies.
I assume that if the single injector mod was used such as a FIM ultimap chip, then the single injector in each body would be ok too?
DC
Old 18-Aug-2005, 19:15   #2
They should be OK the 916 and 996 both have 50mm throttle bodies as standard.
Better option could be a 748R shower injector setup which uses 54mm throttle bodies.
[Edited on 18-8-2005 by skidlids]
Old 18-Aug-2005, 19:24   #3
748mart 748mart is offline
Do all 916's have 50mm throttle bodies? The 2nd hand lump I picked up appears to have 45mm bodies, the same as the 748.
Old 18-Aug-2005, 19:42   #4
Even the 748 has 50mm throottle bodies as measured at the butterfly, they then have a 44mm restriction downstream to comply with the Supersport regs as they stood at the time.
Old 18-Aug-2005, 19:59   #5
DC DC is offline
DC's Avatar
Cheers for that chaps.
What about getting my 748 bodies bored out at the 44mm restriction?
Is this straight forward? Can any engineering firm do this or is it best left to a Ducati specialist?
DC.
Old 18-Aug-2005, 20:14   #6
Oh OK, it looks like I was given 748 ones as they measured approx 45 mim at the downstream end.
Old 18-Aug-2005, 20:15   #7
You could probably get 748 ones bored out at some cost but there must be quite a few sets of 916 ones around that should offer a cheaper alternative. My 996 that I am building at the mo has the standard twin injector throttle boddies but I do have a 748R set of 54mm shower injectors along with airbox that I may see about fitting futher along the line.
My 998 uses slightly different 54mm shower injection and that works fine so a similar set up onthe 996 may be the way to go.
Incidently my 955 engine has a 54mm twin injector setup
Old 18-Aug-2005, 20:24   #8
Sigma performance website is always useful to look at when considering doing these sort of things, mainly under the technical section. Here is the link with the 748 info
http://www.sigmaperformance.com/748s...htm#background
Old 22-Aug-2005, 03:20   #9
Webcore Webcore is offline
I've got 916 throttle bodies and injectors on my 996S engine - works great.
Old 22-Aug-2005, 10:30   #10
DC DC is offline
DC's Avatar
Cheers mate, Thanks for the info.
DC
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:36.
