Old 22-Aug-2005, 14:19   #1
Burglar alarms???
Anyone know anything about these?
I've already got one, an Accenta 8 mini (I think) and it works a treat, various passives and door sensors. But in the next few weeks they'll be the patter of tiny feet, or should I say paws as 2 little kittens arrive and I don't think it has any scope for pets.
Does the actual alarm unit need upgrading? or is it at the PIR level? or a combination of both?
Old 22-Aug-2005, 14:43   #2
Mr_S Mr_S is offline
I think Clockwork Orange is our specialist in this area and may be worth a U2U.
Old 22-Aug-2005, 14:43   #3
Mello-Yellow Mello-Yellow is offline
Bikes: 848 EVO & Multi 1000ds
Mello-Yellow's Avatar
Mood: When's the sun coming out
animal pir\'s
You can buy some animal pir's they are less sensitive than the normal ones, somethin to do with the size of the object that they sense, had some fitted to my system when it was installed.
the other way round it is to put some tape on the bottom of the pir's you already have this will then only sense any object over a certain height, not much good when the little buggers are crawling up the curtains which has happened on a few occasions
Old 22-Aug-2005, 14:49   #4
guest1 guest1 is offline
I reckon the more reliable method would be to use the window/door contacts, but these are susceptible to air/ground vibrations such as thunder etcetera(cos door and window frames DO rattle). If you've got decent frames then they are generally good.
PIR's - need to lower the heights and change the lens' for a pet lens - this cuts off the detection swathe into a level beam. This should be OK for the time being until the kitties learn how to jump up on the furniture and counters. By lowering and using pet lens' then you could "cut" the room down to waist or shoulder height so that anything below it would not be picked up (unless Mr or Miss Burglar goes around on hands and kness - not unheard of).
Anyhow, what are they doing in the house on their own anyway?
Old 22-Aug-2005, 14:50   #5
Keep the cats in a cage whilst you're out?
Old 22-Aug-2005, 14:51   #6
Gaffer tape's your answer;
Simply apply a couple of strips to each Moggie and secure to the floor at night - sorted
Old 22-Aug-2005, 14:53   #7
Old 22-Aug-2005, 15:01   #8
Not so much bothered at night, because we'll be there anyway, just like now I'm at work and they might be in setting the alarm off etc
Old 22-Aug-2005, 15:04   #9
Yes, you need to check your PIR sensors as some are able to distinguish between a cat and a human, so will trigger for one and not the other.
If you don't have the right ones it should be a simple replacement job.
Old 22-Aug-2005, 15:09   #10
COL595 COL595 is offline
Mood: Lascivious
My mate bought a 'special' (expensive) animal tolerant alarm system and had it professionally installed.
Had it done about 6 months ago, and though it's been 'tweaked' by the installer many times since then, he still gets to go home most days to switch it off.
In terms of installation costs, his time and petrol costs when dealing with repeated false alarms, etc. it would've been cheaper for him to be burgled 3 times a year for the rest of his life.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:16.
