Old 22-Aug-2005, 14:27   #1
jj250 jj250 is offline
jj250's Avatar
Strange noise??
When pulling away on my 748 there appears to be a wierd noise, hard to describe but a kind of groan and seems to be coming from rear hub but not sure, its not particularly loud and you almost seem to feel it.....any ideas
Old 22-Aug-2005, 14:36   #2
It's the clutch.
The Duke clutch is a dry clutch and it gets a bit of dust between the plates every now and then, especially if you've got a standard clutch cover. Causes a graunching noise as you pull away
Nothing to worry about, just take off the cover and blow the dust out.
Having an open clutch cover takes care of it
Old 22-Aug-2005, 14:40   #3
jj250's Avatar
cheers jools, the bikes got an open cover on it but i'll check it out later
Old 22-Aug-2005, 14:41   #4
dst1 dst1 is offline
dst1's Avatar
Mood: thrash the bitch
I was thinking about changing to a open clutch cover but would that make a bigger racket than the standard cover.
Old 22-Aug-2005, 15:00   #5
jj250's Avatar
pop your earplugs in and think how much better it looks
Old 22-Aug-2005, 19:38   #6
Fordie Fordie is offline
Regional Organiser - BHCN
Fordie's Avatar
Mood: Raring to Ride
Might be worth having a look at the rear chain to see if you have a tight spot, put it up on the paddock stand and rotate the back wheel. check the full lenght of the chain . 4D
Old 22-Aug-2005, 22:08   #7
rcgbob44's Avatar
Sell it and buy a Honda!
Old 23-Aug-2005, 10:33   #8
jj250's Avatar
Right, had the clutch apart last night, cleaned everything out but now have 2 questions, whats the torque setting for the bolts that hold the springs and colletts and does it matter if the centre of the basket moves as it and the presure plate have marks(timing?) on them
[Edited on 23-8-2005 by jj250]
Old 23-Aug-2005, 12:18   #9
Your supposed to line all the marks up but i have'nt found that it makes much difference. Do the spring bolts up with a small allen key, don't heave on them or your next post will be "help me get a broken bolt out of my clutch". A bit of coppa slip wouldnt hurt.
Old 23-Aug-2005, 13:10   #10
neil748r neil748r is offline
One of the spring posts has a slot on the top of it. You have to make sure that post goes through the hole in the pressure plate with the corresponding mark. Apart from that, anything goes.
Spring cap retaining bolts are torqued to about 5 or 6 Nm, not worth torquing really, just snug them down by hand using copper slip grease or molybdenum disulphide grease on the threads.
[Edited on 23-8-2005 by neil748r]
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:47.
