Old 30-Jul-2003, 11:19   #1
Founder Member
Paul James's Avatar
Gearbox ratios ST2
Odd one this...my'98 ST2 fitted with 15 tooth front and 42 tooth rear sprocket revs too much (about 85mph @6,000rpm).
I've fitted a 39 tooth rear sprocket and it now runs just under 100mph @ 6,000 rpm.
The later bikes run 15/42 sprockets but seem to do around 100mph @ 6,000.
Anyone got the gerarbox and primary drive ratios for an early ST2 ?. Must be a change in the gearbox and my guess is it's the primary drive ratio that's been altered as it would be a real pain to change all the gearbox ratios.
Old 30-Jul-2003, 11:53   #2
ST4 ST4 is offline
My 1999 ST4 does 80mph for 5000 rpm on standard sprockets and with a 14 tooth front this goes up to about 5750. I dont think my ST2 (1998) that i used to have would do 100mph for 6000 rpm though, at 80mph it was the same 5000 rpm as the ST4.
Probably no help to whatsoever though!
Paul.
Old 30-Jul-2003, 13:09   #3
There doesn't appear to be any changes to the primary gearing from what I can find Paul.
The ST4 runs different primary ratios, so that explains that one.
Only thing that could make a "significant" difference is the tyre profiles etc. ie, the new Diablos are quite a tall tyre, visibly more than my old 010's.......
Don't the later bikes run a 180?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 00:49.
