Old 24-Aug-2005, 21:28   #1
DSC Member simonducati simonducati is offline
Bikes: Had 748,749, 848 and now a 1199 Panigale
simonducati's Avatar
Mood: Living the dream.
Help please ASAP.
Help please ASAP.
My bike broke down on me yesterday it wont start, it makes a nook noise when I try and start it, and the breakdown man sad it sounds like it is the starter clutch, so I have got the bike in the house now but I cant get the alternator rotor off to see?
By the way the rotor nut was lose can that be the problem ?
Helllllllllllp please
Old 24-Aug-2005, 21:38   #2
domski's Avatar
I think a couple DD boys had a loose rotor nut early in the season, and I believe that made them stop too.
Can't help you though, sorry
Old 24-Aug-2005, 21:44   #3
m1keyp m1keyp is offline
Alternator nut should be torqued and loctited as part of a service schedule
If lose it may well have been what was causing the problem.
Mike
Old 24-Aug-2005, 21:53   #4
ok mate, i give it a go and let you no.
Old 24-Aug-2005, 21:56   #5
keefer keefer is offline
keefer's Avatar
you should not just do it up.
there is a washer that sits at the back of the whole assembly and can slip of slightly and cause everything to be out of sync.
strip it all down and put it back together correctly then tighten up the nut
Old 24-Aug-2005, 22:00   #6
how do i get the rotor off
Old 24-Aug-2005, 22:01   #7
Old 24-Aug-2005, 22:02   #8
keefer's Avatar
im trying to find a link 4U
Old 24-Aug-2005, 22:05   #9
ok thanks, the flywheel is lose towhen i move the rotor is that ok?
Old 24-Aug-2005, 22:14   #10
keefer's Avatar
http://www.mad-ducati.com/Technical/...torCover2.html
thanks go to shazaam!
