Old 27-May-2013, 23:08   #1
pguenet pguenet is offline
FS - Bursi 998 Throttle bodies + Race Heads and 1038cc kit
Selling as set of 998 S throttle bodies with Bursi evo bell mouths.
I would rather sell as a set.
I can get you the manifolds and standard or 12 holes red tagged injectors (the super expensive ones)
Looking for £500 as is (bodies . bell mouths, no manifolds or injectors)
I am also selling set of 998 S heads which have been ported + flawed, including 749R cams (higher lift), 102 bore barrels and high compression Pistal pistons. I have the manifolds matching the ports. This set of heads also has bigger 42 mm inlet valves and different valve guides.
This set up saw 170 bhp on the 998s.
Looking for £1,500 for this. Note that the pistons + rebore alone cost over £1000 from Ducati Kamna.
Gonna take those off soon can can send pictures then.
Untitled by desmophil, on Flickr
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 04:55.
