Old 26-Aug-2005, 01:00   #1
Spank Spank is offline
Front fork adjustment
I've got the new 749 Biposto but I can't see a compression damping adjuster on the fork leg. Is this because there is no compression adjustment?
Old 26-Aug-2005, 01:49   #2
Ducati Dealer
wilf's Avatar
Hard to find if you dont know where to look...
Bottom of the fork leg, the spindle has a hole through it that has to be lined up, if you have had tyres fitted by a non Ducati mechanic this will be out of line almost certainly, you need a small (3-5mm) flat head screwdriver to go through the spindle into the adjuster.
can U2U a pic if you want one.
Old 26-Aug-2005, 19:49   #3
Suspension Sorted
Thanks, I've found the adjuster and softened it up for running in.
