Old 26-Aug-2005, 15:34   #1
jj250 jj250 is offline
jj250's Avatar
sil moto pipes - any good?
just wondered if anyone has experience of sil moto pipes and if so opinions of them, would i notice any benefit of 54mm pipes over standard 748 ones with termis?
Old 26-Aug-2005, 15:39   #2
Quality is spot on. They are OE manufacturers for some of the DP exhausts.
54mm would sound and go pretty well top end, but you'd knock some of the midrange out.
Old 26-Aug-2005, 15:50   #3
I have 54mm on my 996 - they rock!
Old 26-Aug-2005, 16:14   #4
jj250's Avatar
cool, would the bike benefit from a power commander with said pipes fitted, its currently got a chip and pipercross sock filter
Old 26-Aug-2005, 16:46   #5
phil_h phil_h is offline
phil_h's Avatar
If its a 748, then anything over 45mm gives a mid-range hole that 'chipping' wont fix.
If you just want to rev it and get more top-end then any 50's and a chip will be fine.
This is not particular to ducs - its a volume-of-gas thing that affects any bike. 'Over-exhaust' an engine and you'll lose midrange.
Old 26-Aug-2005, 20:55   #6
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
SilMoto pipes, great.
[Edited on 26-8-2005 by rob41b]
Old 27-Aug-2005, 02:29   #7
fatduke11111's Avatar
They sound luverly.. had to swap them for the standards ones on the MOT and the 996 sounded like a sewing machine....got them back on...sound great!
Old 27-Aug-2005, 03:07   #8
I can't really say for a 748 mate.
Your best bet is to ring Neil Spalding @ Sigma Performance and have a chat to him.
Good luck
Old 27-Aug-2005, 22:49   #9
748IOM 748IOM is offline
Mood: Yellow!!
My understanding was that you can either use a chip or a power commander, using both just cocks things up.
I would look for 45mm pipes myself to keep a decent midrange.
Old 28-Aug-2005, 00:02   #10
jj250's Avatar
"My understanding was that you can either use a chip or a power commander, using both just cocks things up."
The bike has 45mm termis at the mo, i just fancied a bit more noise but dont really want to rev the balls off it all the time, as for the chip/power commander i was planning on putting in a standard chip and using a power commander instead
[Edited on 27-8-2005 by jj250]
