Old 28-Aug-2005, 00:29   #1
Ian Harris Ian Harris is offline
Ian Harris's Avatar
Fairing Repair
Looking for suggestions on re-spraying a fibreglass fairing panel.
Following a "major muppet moment" coming out of Druids, my R/H track side panel is looking a bit "shop-soiled". Structurally, its fine, but the surface is comprehensively mullered. I'm going to sand it down and re-spray it..does anyone have any suggestions as to what easily obtainable aerosol spray paint gives a fairly good match to Ducati Red?
Any advice gratefully received...Many thanks, Ian
Old 28-Aug-2005, 01:07   #2
Carbon749's Avatar
Mood: I own a flame thrower
Ian,
Two suggestions for you.
1. take the panel to the local automotive refinishers / paint suppliers and ask them to mix a colour to match the panel and fill an aerosol for you, probably cost around £7.50 ish.
2. I painted my frame and wheels in Ducati Rosso Red made by Debeer. This is a very close match. Again a decent paint supplier will fill you an aerosol with some of this. Should add that this is a good match for the red on an 03 749. Not sure if there are different types of red used.
Hope this helps you.
[Edited on 28-8-2005 by Carbon749]
Old 28-Aug-2005, 06:26   #3
Bionicle Bionicle is offline
Bionicle's Avatar
The paint code for Ducati Red is PPG 473.101 most places will be able to get hold of it for you
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:51.
