Old 28-Aug-2005, 04:22   #1
edwyun edwyun is offline
Custom spaghetti\'s with sound clips
Here's my page about the custom spaghetti's with sound
clips!
http://www.geocities.com/edwyun/spaghetti.html
enjoy =)
Old 28-Aug-2005, 15:56   #2
Screwy Screwy is offline
Screwy's Avatar
Very nice , Would love a set of those on my 851/888
Old 28-Aug-2005, 16:58   #3
VERY NICE - I'd love to do away with the narrow link section in the header and the narrow section of the cans inlet.
Great work - dyno report on the way please ???
[Edited on 28-8-2005 by Iconic944ss]
Old 28-Aug-2005, 18:04   #4
Thanks all.
I did dyno the system, but due to high humidity, the numbers are a bit suspect. Plus, I installed the dual FCR's at the same time and only got to dyno the low mount system, which apparently doesn't flow as much as the high mounts. Even so, I got about 4hp. Will be doing a another dyno with both low and high mounts soon.
Old 11-Sep-2005, 01:01   #5
Dynoed the system and here are the results (all in SAE, although the dynos are taken on different dynos and of course on different dates):
BEFORE: OEM Mikuni carbs, Dynojet stage II, BMC airfilter with perforated airbox cover, 944HC Pistal pistons, BCM mild head porting, lightened flywheel, OEM headers, Termi slipons, = 82.1 HP and 68.5 ft-lbs torque.
AFTER: same as above but with 41mm FCR's and the custom spaghetti's = 85.8 HP and 75.1 ft-lbs torque.
But what you can't see in these numbers is that with the spaghetti's/FCR's, the "brickwall" that the 2V engine hits above 7500 RPM is much less and HP tapers off less. Nice.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:09.
