Old 29-Aug-2005, 02:32   #1
zhed44 zhed44 is offline
zhed44's Avatar
Mood: YELLOW!!!
Clip on risers. Anyone had them on their bike?
Although I'm a man, being blessed (or cursed) with the delicate wrists of woman I've just bought a set of risers on eBay. According to the auction info they're Ducati Performance items, the master cyl bracket is included and they raise the bars by about an inch.
Has anybody ever fitted these type of risers to their bike, and if so, what can I expect in terms of clearance/fouling issues and increased comfort and/or decreased mirror visibility issues?
Thanks.
Old 29-Aug-2005, 12:24   #2
crm250 crm250 is offline
crm250's Avatar
Mood: Firing on all 4 !!
Fitted the cyclecat bars to my 916, made a massive difference for my spain trip. (sadly they didnt manage to stop it breaking down)
no worries with clearance, only thing i would say it can get a bit tight on full lock and your thumbs in the tank.
On the upside - as you have to rotate your throttle grip 180 degrees, it means if adjusted correctly that you can use the choke button as a cruize controll - mine would sit at 75 - 80 mph once pressed
Old 29-Aug-2005, 13:18   #3
Totto Totto is offline
Had the DP raisers fitted to my 998bp & did not like them at all , sold them on this site , i found the best thing to do is to rotate the clutch/brake levers round which means your wrist's are not bent when operating them
This makes a huge difference ,so much now that my backside is usually the first to give in
Doing this will mean you have to either remove/file down the pins thaT locate the clip ons in position ,but as long as you mark the std position it easy to put back to std
Hope this helps
Old 29-Aug-2005, 23:25   #4
zhed44's Avatar
Mood: YELLOW!!!
thanks. i'll see how i get on, and if i don't like 'em i can always put them back on ebay.
btw: i've put renthal soft grips on and that's made a hell of a difference to comfort
Old 30-Aug-2005, 00:14   #5
m1keyp m1keyp is offline
Cycle Cat Simply brilliant +++++
Old 30-Aug-2005, 02:05   #6
zhed44's Avatar
Mood: YELLOW!!!
just been outside to have a closer look at my bike re: the clearance issues etc and it seems that if they do raise the bars by 1" then:
a) the top of my fingers will be awfully close to the edge of the screen when on lock (don't know how far away when not on lock 'cos i didn't want to move the bars and set the alarm off!)
b) the throttle switch gubbins will need to be shifted to avoid fouling the screen
c) my hands or forearms will be in the way of the mirrors
mmmmm......am i correct?
[Edited on 30-8-2005 by zhed44]
Old 30-Aug-2005, 13:26   #7
With the Cyclecat
The top of your hand will be close to the fairing on full lock, this only matters in car parks but its not that bad and you know the limits of the lock it is not a problem.
The throttle unit is rotated through 180 degrees and is not a problem.
What mirrors
They really are the dogs, if you are anywhere near me let me know.
Regards
Old 31-Aug-2005, 00:17   #8
zhed44's Avatar
Mood: YELLOW!!!
Old 31-Aug-2005, 00:33   #9
BDG BDG is offline
BDG's Avatar
I have the wrists and fingers of a man who has crashed too many dirt bikes into trees, dry stone walls etc (7 fractures ) and could not get on with standard bars on 996, Helibars work wonders for me and transform the bike and can even tour on it as well.
Old 31-Aug-2005, 01:00   #10
I find the mirrors are usable now I have c.cat bars fitted
