Old 29-Aug-2005, 10:56   #1
alan_db alan_db is offline
V piece Bolts....?
Anyone had bother with the upper bolts on the v-piece which attach to the inside of the side panels?
The tapped hole on my left hand panel is knackered (was like this when I bought bike).
It looks like a steel nut has been glued into the hole but this popped out couple of nights ago when I was putting bike back together.
Any ideas on how to fix it, tried Araldite but it didn't hold very well.
Alan...
Old 29-Aug-2005, 11:20   #2
pibbow pibbow is offline
Mood: Very sad
Try some resin from Isopon body filler or the like. Its a common problem
[Edited on 29-8-2005 by pibbow]
Old 29-Aug-2005, 11:24   #3
Cheers, will try that.
Alan...
Old 29-Aug-2005, 14:50   #4
Gaz 748's Avatar
Hellicoil, about £5-10 at any bike shop, had one of mine strip.
Old 29-Aug-2005, 19:29   #5
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
You need a new Tapex Insert. I have some on the bench ready to be epoxied into virgin panels.
Rgds, Rob
Old 29-Aug-2005, 22:52   #6
Gaz 748's Avatar
Sorry, I thought you ment the front rocker cover mount
Old 30-Aug-2005, 00:27   #7
weeveetwin's Avatar
Don't you just hate those things..? Cr*p design, in my opinion. In fact, they're almost as bad as the useless chain adjusters. (Every time I adjust the chain on my 888, it practically crabs sideways along the road..!)
Talk about 'spoiling the ship, for a ha'porth of tar'. Did the same team who designed the desmo valve system really come up with these things??
Old 30-Aug-2005, 12:14   #8
Rob, where'd you get the tapex inserts, think thats what I'm going to need.
Managed to get a plain old hex nut to hold last night but it doesn't let me get the screw in far enough!!!!!!
Held the v-piece in to allow me out to ride the bike, which is funnily enough the reason I bought it.
Thought I had the bike sorted and everything spot on before this. This Ducati 'character' can show in loads of ways eh!!!!!
Alan...
Old 30-Aug-2005, 12:28   #9
Rob B's Avatar
Managed to order/blag them for one of the retailers. Try Clarendons or some such.
Rgds, Rob
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:47.
