Old 30-Aug-2005, 19:33   #1
dst1 dst1 is offline
dst1's Avatar
Mood: thrash the bitch
Fit Optimate
I want to fit my Optimate to my 916.
I have Dzus fasteners on both sides of the fairing, can you tell me in what order do I need to remove the bodywork.
Or can I just remove the battery side fairing.
Old 30-Aug-2005, 19:36   #2
NBs996 NBs996 is offline
NBs996's Avatar
Mood: I love my 996 xxx
When I plug in my optimate using the croc clips straight to the battery, I just pull the two dzus fasteners from the rear of the right panel and ease the panel out. No need to remove any bodywork.
Old 30-Aug-2005, 19:37   #3
Just take the battery side off, 4 upper and the two underneath which bolts the sides together
Old 30-Aug-2005, 19:49   #4
tricky tricky is offline
Mood: Need spares
I've run a cable up the frame from the battery and used the connectors supplied with the charger so there is no need to remove the fairing. The extension is just tie wrapped to the frame near the top of the fairing, so its just a case of reaching down and pulling up the wire, plugging in and charge away.
Old 30-Aug-2005, 19:55   #5
les996 les996 is offline
les996's Avatar
Mood: :-0
likewise, I have mine with the extension clipped to the frame just above the clutch, works a treat
les
Old 30-Aug-2005, 20:05   #6
dst1's Avatar
Many thanks Chaps
Old 31-Aug-2005, 00:40   #7
rcgbob44's Avatar
I have mine fitted and have the plug under the seat.
Old 31-Aug-2005, 03:31   #8
Crunchy Crunchy is offline
Crunchy's Avatar
Errr whats an Optimate???
Old 31-Aug-2005, 08:24   #9
Its a fancy battery charger that allegedly monitors the state of the battery and tops up the charge,if required.
The jury is out to whether they actually work tho!
Old 31-Aug-2005, 15:47   #10
m1keyp m1keyp is offline
Got one of the fly leads with the waterproof cap
http://www.accumate.co.uk/cg020001.html
Works for me
