Old 02-Jun-2013, 09:29   #1
jadiles jadiles is offline
Newbie
Bikes: Ducati 996 & Triumph Sprint ST1050
jadiles's Avatar
Mood: Feeling fine!
996 Lower Shock Bolt Seized
Hi Guys
Need some advise! I'm trying to remove the rear shock from my 996 and try as I might I cannot remove the lower bolt (steel bolt into alloy insert).
Tried everything heat power bars you name it
Can the head of the bolt be drilled out?
Thanks in advance John
Old 02-Jun-2013, 11:14   #2
Probably rusted into the steel insert on the other end, drilling might be the only option, depending which end you drill from you need to drill out a good 10mm or more
Old 02-Jun-2013, 11:38   #3
Newbie
jadiles's Avatar
Mood: Feeling fine!
Thanks for the advise
Old 02-Jun-2013, 12:25   #4
Had the same on mine last year. Short of me wrecking it I decided it was best to just take it to my local bike shop and get them to do it. Only cost me 1/2 hr labour and they copper greesed it so it wont stick again.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:24.
