Old 02-Sep-2005, 18:33   #1
marchesini marchesini is offline
ST4 Radiator size (again)
I posted a while back about the size of the ST4 Radiator size and got the measurements of 330-350 x 200 (ish). Could someone please check that is the complete radiator size including the header tanks or just the core only. If it like my S4R, the header tanks 'should' be 35mm wide each making a total rad width of 420mm. If so then it is more than likely the same radiator used across the range which sort of scuppers the plans to make the radiator smaller.
Thanks again in advance
Best regards
simon
Old 02-Sep-2005, 22:15   #2
If you download the parts catalogs from www.ducati.com then you can check the part numbers to see if they are the same.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:02.
