Technical - Help or Info - NON Motorcycle
PC's, Internet etc. Cars, or how to fix that leaky radiator - in here please!
Old 05-Sep-2005, 10:10   #1
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Web Team - help & advice please - attachements
I have just converted my two pc's so they share a single DSL connection through a Netgear router/firewall. Now, when I post attchements, they seem to take an age (sometimes timing out alltogether) Can't send emails with attachments either.
Most everything else works well, including normal posts, such as this one.
TIA.
Rgds, Rob
Old 05-Sep-2005, 11:09   #2
Hmmmm....I'm using a Netgear firewall/router as well and dont seem to have problems doing that.
The netgear site has a pretty good Q&A section.
The probs I've had was with a game my daughter used to play over the net that now crashes out regardless of the gaming options I've selected and my inability to share a printer connected to the network - ho hum.
Good luck - Frank
Old 05-Sep-2005, 11:13   #3
Rob B's Avatar
Frank,
Thanks, do you have any s/w firewall or anti virus s/w running?
Rgds, Rob
Old 05-Sep-2005, 11:24   #4
Yes Rob - Zonealarm f/wall and AVG anti-virus.
Everything else I need to do on the laptop (now) and main PC all work fast and fine. Network is wireless and uses the WGT624 router.
It all configured itself really.
Frank
Old 05-Sep-2005, 11:30   #5
Craig G Craig G is offline
Mood: Fed up
Is it a new router? or did you use it previously with just one machine?
Old 05-Sep-2005, 11:47   #6
Rob B's Avatar
Used it for months (the router/firewall) on a separate dsl line, and my pc (the one with the issue) all worked OK until I started running it across the LAN.
Old 05-Sep-2005, 11:51   #7
If the issue is with only one PC it would seem to point to config with just that machine. I take it sending email/attachments from your other PC is OK?
Frank
Old 05-Sep-2005, 11:53   #8
Some info from Netgear:
http://kbserver.netgear.com/inquira/...iction=kb_file
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:32.
