Old 07-Sep-2005, 08:59   #1
loverobot's Avatar
Front axle nut size for a 600ss
Could someone please tell me the size of the front axle nut on a 96 600ss? I need to get the front wheel off for the first time and have found that instead of it being a standard nut it is instead hollow and requires an allen key style socket that is much larger than i currently have
Also any idea who sells such an item, preferably tht will fit on a 1/2" drive?
Old 07-Sep-2005, 09:05   #2
I think its 14mm but not sure I can check after work, but if you have a 10mm bolt around with a 14mm head you could check yourself if its quicker.
I use a 3 stepped hex key that I got of Dennis Trollope Racing it has 14,17 & 19mm hexs on it, as I said I think its the 14mm end I use
Old 07-Sep-2005, 09:09   #3
loverobot's Avatar
Thanks skidlids - I was all set to whip the wheel off last night and then duh axle bolt - never thought about the bolt idea! Do you know of any decent toolshops online that sell specialist stuff? I am guessing your stepdown hex wont fit on a drive and therefore not on a torque wrench either?
Old 07-Sep-2005, 11:14   #4
Mine is a bit like this
http://cgi.ebay.co.uk/KAWASAKI-ZXR-O... cmdZViewItem
So you can fit a torque wrench and socket on the other end.
Old 07-Sep-2005, 11:19   #5
looks about right
http://cgi.ebay.co.uk/BRITOOL-1-2-DR... cmdZViewItem
Old 07-Sep-2005, 11:25   #6
loverobot's Avatar
Wow! Thanks very very much for that - it is probably the most helpful reply I have ever had on a bulletin board! Thanks!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:09.
