Old 07-Sep-2005, 19:45   #1
pibbow pibbow is offline
Mood: Very sad
Shaking it\'s head!
HELP!!! as some of you will no I don't get out much, so you can only imagine how uterly pi??d off I was last thursday. I was gien a day pass and headed to the mainland for a blast 20 mlies in I sat up slightly at around 50mph to wiggle some blood back into my hands as I did the bike started to shake its head. I tried it again at 60 and all was well until the speed dropped to around 55 then it did it again so rather than just grab the bars I just hovered with my hands just above. The shake got worse then fell away below 50. Now I know what your going to say "why take your hands off the bars at speed" Well I don't make a habit of it but I have never had this before. Anyone have an idea of the cause.
[Edited on 7-9-2005 by pibbow]
Old 07-Sep-2005, 19:52   #2
sparkin sparkin is offline
sparkin's Avatar
Might be obvious,but have you checked your tyre pressures?
Old 07-Sep-2005, 19:53   #3
Mood: Very sad
Yes mate first thing I did they were spot on
Old 07-Sep-2005, 19:56   #4
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Tyre wear? On one of my bikes if my fronts wear E.g. the tread gets uneven across the leading/trailing edge of the cuts, it'll do exactly what you describe.
Rgds, Rob
Old 07-Sep-2005, 19:58   #5
sparkin's Avatar
Ok,bent wheel?poorly seated tyre?
Old 07-Sep-2005, 20:01   #6
Dave G Dave G is offline
Dave G's Avatar
Check if the tyre balance weights might have come off too.
Old 07-Sep-2005, 20:02   #7
Mood: Very sad
Well The tyre has done about 2000 miles but it has not shark's toothed yet but I will have another look tomorrow. I have the bike up on paddock stands and have spunn the weel and both it and the tyre seem spot on?
Old 07-Sep-2005, 20:04   #8
Mood: Very sad
Thank's dave there are some on but I will have a close look to see if any have gone astray.
Old 07-Sep-2005, 20:13   #9
ericthered40's Avatar
Mood: renegade sexy racer
Could it be Tire, wear or balancing, head race bearings or brake calliper sticking. look at the wheel bearings to?
[Edited on 7-9-2005 by ericthered40]
Old 07-Sep-2005, 22:32   #10
phil_h phil_h is offline
phil_h's Avatar
It sounds like the steering head bearings are starting to wear.
Too many wheelies mate
