Old 08-Sep-2005, 13:14   #1
rxtim rxtim is offline
916 45mm Termi Carbon Cans / EPROM
I've just put a pair of 45mm carbon termis on my 1995 916 BP.
They came with the correct chip, but guessing it is fried since the bike doesn't run with it fitted, I've put the original in and all is fine.
Am I safe to run with this set up, or for peace of mind should I get a new suitable chip and replace the standard one?
Old 08-Sep-2005, 13:16   #2
beancounter beancounter is offline
beancounter's Avatar
Mood: Black and grey (and a bit of red)
I wouldn't run it hard without the correct chip as you risk running it too lean (bad).
Replacement chips are cheap (hah !) try JHP.
Old 08-Sep-2005, 13:48   #3
phil_h phil_h is offline
phil_h's Avatar
It is possible fit the chip one pin out of alignment - which _shouldnt_ blow it up.
Alternatively, 1 pin of the chip is bent or broken too short and not making contact.
If you want to send it to me I can check that its ok at work (electronics engineer) and poss still make a copy if its a broken pin.
I've run my 748 with 3 different chips and with different power commander maps with different chips.
If its too lean the performance goes off, and you will know that all is not right !
The engine will run (poorly to badly) with a lean mixture but because it also runs hotter, you really musnt run it lean for any length of time or your piston will let you know it doesnt like it
Old 08-Sep-2005, 13:59   #4
Pretty sure it was in OK, fuel pump didn't prime with it in.
Re-fitted original and it was fine.
Old 08-Sep-2005, 15:59   #5
phil_h's Avatar
That has happened to me when I was changing a chip without enough light to see what I was doing (doh!)
The offer stands if you want the chip checked out.
Old 08-Sep-2005, 19:43   #6
dst1 dst1 is offline
dst1's Avatar
Mood: thrash the bitch
Some info I got from Neil at cornerspeed (nelly) that there is a mark on the e-prom denoting which way it should face, some sort of mark on the chip.
Are you aware of any mark on your e-prom, it should face towards the tank
Old 08-Sep-2005, 20:53   #7
It's fitted the correct way with notches lined up, I tried it again with good light same result.
Old 08-Sep-2005, 22:22   #8
dst1's Avatar
I recently purchased some 50mm Termi`s and got a chip from JHP in Coventry, just under £30 and it came via post the next day, these are recommed by Neil at Cornerspeed
Worth a call
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:43.
