Old 08-Sep-2005, 21:08   #1
stephen hall's Avatar
lock tight
can i use the lock tight i have to replace all the bolts on my clutch replacement it is medium strength 428 ? thanks
Old 08-Sep-2005, 21:19   #2
Rushjob Rushjob is offline
Rushjob's Avatar
Mood: :-)
Loctite 510 according to the workshop manual ( for the M8 x 1.25 mm bolts fixing the drum )
Old 08-Sep-2005, 21:40   #3
Yep, fine on the bolts holding the drum but dont use any on the little ones holding the springs in.
Get back to your revision Andy!
Old 08-Sep-2005, 23:21   #4
YMFB YMFB is offline
YMFB's Avatar
If you use loctite on a thread does it just make it sticky and less likely to undo or more like varnish making it difficult to undo ?
On my ST4 the plastic panels that go along side the seat and up towards the pillion grab handle are difficult to fit using the bolts supplied. I have replaced the bolts with a short piece of allthread screwed into the panel then all I have to do is fit the nut and washer, job done. So far they havent come loose but Im sure they could so I was considering using loctite to set them once and for all.
What do you guys think ?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:36.
