Old 10-Sep-2005, 15:05   #1
aka.eric aka.eric is offline
Exhaust Manifold Gaskets
The new gaskets look a bit cheap and nasty,half the thickness of the old ones,look ready to leak as soon as the engine fires.Should any sealing compound be used when fitting?.
Old 10-Sep-2005, 15:17   #2
748mart 748mart is offline
They are the same as the gaskets on the 916, Haven't had any leaks & not required sealing compund.
Old 10-Sep-2005, 22:17   #3
gaskets
yep there the same ones I got from ducati Coventry and Ive had no probs with them yet I just fitted S/S flanged nuts instead of the steel ones I took off.
Are your pipes still off the bike if so you want to change the 2 analyser plugs for brass ones as I had to drill out the old and they where extremely hard.
ian
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:47.
