Old 12-Sep-2005, 11:08   #1
851neil 851neil is offline
Mood: need a bike...
Found - Rear Shock
I'm still chasing after a new rear shock ! just had confirmation from Maxton that mine is jim rucked, so I'm well and truly stuck now.
Any help at all in sourcing a new shock would be greatly appreciated - hopefully I can get one sorted before the weather totally disappears.
btw Harris said they could get Ohlins to build one up for me but it would be neck end of £500
It would be good to add to the 260 miles totted up since her rebuild
[Edited on 13-10-2005 by 851neil]
Old 17-Sep-2005, 09:01   #2
loony888 loony888 is offline
Mood: sensational!!
i have the std. showa from my 888 if you're interested.(12,000klms). i'm in oz though so not sure about air mail cost if you're in a hurry. contact me if you want it. gosh, don't even know what to ask for it!
Old 19-Sep-2005, 09:47   #3
I've, managed to get hold of a used one from fleabay thanks - not sure what it's going to be like, but it's an Ohlins & I'm hoping that I've not thrown money away.
cheers
Neil
Old 07-Oct-2005, 18:33   #4
Received the Ohlins shock yesterday - opened the box and it's mint, no worries, fitted her up last night and took the bike for a good run out today.
yeeeeehah
The only issue is that there isn't a screw fixing for the remote reservoir - the old marzocchi item had a couple of mounting points onto the subframe. Any suggestions or am I resorting to zip ties ??
Old 07-Oct-2005, 18:48   #5
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Glad it worked out for ya.
Rgds, Rob
Old 07-Oct-2005, 20:11   #6
philthy philthy is offline
philthy's Avatar
Mood: Can't make me mind up
Scuse me ignorance but wot do you pump the stock shock up with?
I was filling it with air but I'm sure maxton told me to use nitrogen, but I use that in the garden.
Help would be appreciated
Phil
Old 09-Oct-2005, 17:25   #7
I've been told to use air - but Nitrogen is a great idea it'll be much more stable with varying temperature extremes, hadn't thought of that one till now...
