Old 12-Sep-2005, 21:44   #1
stephen hall's Avatar
what year?
can anyone tel me what year the clutch was fitted with the rubber gasket on the 900? I have been offered a 900 engine from a write off it is minus the rear cylinder and apart from the rubber gasket a thingmy on the oil net drain plug it looks the same as my 94' the clutch shows no wear I changed mine at 19000 well worn. the rest of the cycle parts are sold those that were of any use, front end big style ouch! what should i offer for the rest as spares?
Old 13-Sep-2005, 01:05   #2
Hi Stephen, Not sure about the extra seal on the slave cylinder - will check the books I have and try to get back to you.
Someone on the net was offering a 93 900ss for spares minus exhausts and rear hugger for £1K.
Front ends seem to go to 200-300 so on that basis I'd say less than £700 on that basis - is the frame ok ????
Frank
Old 13-Sep-2005, 01:16   #3
monstermob 998's Avatar
is the "thingamy on the oil net drain plug" are you reffering to an electrical connection??? if so this is a oil temp sender unit --i could be wrong tho
Old 13-Sep-2005, 05:33   #4
edwyun edwyun is offline
Hard to tell from your description but...
If there is no boss for the kickstarter on the right, lower, rear side of the crankcase, it should be a 1996 or 1997 motor.
If the oil screen plug is just a seven point, this means the bike did not have an oil cooler and thus is probably a 92, 93 or even a 94. But if the oil screen plug has a little knub conector ( this is for the oil temp sensor and rubber boot as MM998 pointed out), this means the engine is maybe a 94 and more likely a 95-97 motor.
The sound deadening gasket for the clutch cover appeared in around 96 or 97.
The only thing I would be concerned about is getting a 97 or 98 motor that came from a Monster, as those engines had smaller valves than the std 900 2V motor.
HTH
Old 13-Sep-2005, 15:26   #5
Edwyun - you rock and can come over and scrape my footrests anytime!!!
Good knowledge!!!
Frank
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:38.
