Old 16-Sep-2005, 19:16   #1
duc daz duc daz is offline
duc daz's Avatar
suspension set up ,,please help
im getting a lot of dive on the front end when i brake hard .on my gixxer you could adjust it on the bottom of the fork leg. were do you do it on the 999
Old 16-Sep-2005, 19:21   #2
Sounds like more compression damping is required? Someone who knows something about suspension might be able to confirm or deny that?
What model is it? As in, are they the ohlins forks?
Old 16-Sep-2005, 19:22   #3
It will be in your owners manual I assume BTW.
Old 16-Sep-2005, 19:33   #4
HW HW is offline
If it's the Showa forks then there is a hole up under the bottom of the fork leg to poke a screwdriver in. Not sure where on Ohlins it would be.
Old 16-Sep-2005, 20:12   #5
duc daz's Avatar
cheers HW
Old 16-Sep-2005, 21:51   #6
pedro pedro is offline
pedro's Avatar
Mood: r
quick spin up to k-tec daz? 5 mins from mine.
Old 16-Sep-2005, 22:49   #7
HW HW is offline
The technique for checking the front forks is to put a tiewrap around one leg and push it up against the oil seal. Then go for a ride and when you stop you will hopefully not have the tie wrap right at the bottom. If it is right on the bottom of the leg then you have run out of suspension and need to sort the preload (big adjuster nut at the top). The RATE of dive is controlled by the compression though, which will be on the bottom somewhere.
Old 16-Sep-2005, 23:22   #8
Melnie Mouse Melnie Mouse is offline
Melnie Mouse's Avatar
Mood: Smiles
I think Psychlist knows someone good on setting up suspensions, why not ask him? I think he's helped a few people before...
Old 16-Sep-2005, 23:35   #9
rob jones rob jones is offline
You need to go back to basics,
1. set the sag front and rear
2. g test
3.measure the travel
4.damping
Old 17-Sep-2005, 00:10   #10
bike mad bike mad is offline
bike mad's Avatar
if it's like my 1 good luck, I think it's the spring, Ive tryed the rebound,it helps but the forks go down in the end, I think I need a more progressive sping but I will try to adjust it for a bit longer befor I pay out for some springs
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:16.
