Old 20-Jun-2013, 20:28
richie0449's Avatar
richie0449 richie0449 is offline
Bikes: gsxr 600 k7 (looking for duke)
Cutting out.
Evening troops,
My 1098 has started to cut out on me. It normally happens only after I've been shifting on and then rolling to a junction to stop. Soon as I press the starter button it fires up straight away no problems.
I had it in for service last week and they adjusted the TPS valve ? To stop it but it still doing it.
As I say it only does it after shifting on and doesn't cause any other problems. It's just a little annoying.
Any ideas ?
Richie.
Old 20-Jun-2013, 22:14
Some of the early bikes suffered with this a little. The DP ECU helped because you could trim and setup the fuelling better. If the bikes stock, a half turn out on the rear air screw helps, maybe a further half turn if the first tweak 'almost' works.
You can see the rear air screw thru the frame just to rear of the throttle body. It's a brass screw about 10mm diameter.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:21.
