Old 21-Sep-2005, 11:25   #1
paynep's Avatar
Mood: Wet wet wet
Late Monster ride height adjuster?
I've had a quick search to no avail, so
Does anyone know if the adjustable rear ride height tierod off of a 9*6 etc will fit a 2002-onMonster?
Or do I need to look for an S4 or S4R one?
Cheers, Paul
Old 21-Sep-2005, 11:43   #2
S4R has a single sided swinger doesn't it? Ride height rod will be different (I think, someone who has more S4R knowledge might be along in a minute)
For a double sided swinger, the Monster chassis and ST's use virtually identical components. If you cross check the parts lists from Ducati.com you'll find that, as an example, most of the part numbers for the rear swingarm assembly are absolutely identical and some differ in that the number is the same, but there may be an A at the end of the number for monsters and a B at the end of an otherwise identical number for the ST.
I'm pretty sure (without actually cross checking) that the ride height adjuster for the 1000DS Monster, the S4 and the whole ST range is identical
Old 21-Sep-2005, 11:51   #3
HW HW is offline
If not, then I have an ST2 ride height adjuster and we have an 03 M620S here which has the adustable ride height. I can go dig out the bits if you need me to, and the ST rod is spare.
Old 21-Sep-2005, 15:31   #4
I've got a 748 one on mine.
Tim
Old 21-Sep-2005, 18:44   #5
domski's Avatar
Get some shorter legs - it will give the same impression
Old 21-Sep-2005, 22:54   #6
paynep's Avatar
Mood: Wet wet wet
HW - if you have the ST one going spare, U2U me with what you want for it.
Tim - 9*6/748 is Plan B then
Dom - tw8t ! :P:P
TTFN
Old 21-Sep-2005, 23:08   #7
domski's Avatar
Originally posted by paynep
Dom - tw8t ! :P:P
You're welcome
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:36.
