Old 24-Sep-2005, 19:21   #1
rob748b rob748b is offline
rob748b's Avatar
Mood: happy dayz!!
748 Tyres Help!!
Hi
I need to replace the rear tyre on my 748 bip and dont know what to go for at the moment??
I am running Bridgestone Battlax at the moment and want to try something else, i want to go for a 180 rear....
Any suggestions??
Rob
Old 24-Sep-2005, 20:36   #2
What or how do you use the bike.............long road rides, track days,or fast blasts?
Old 24-Sep-2005, 20:40   #3
Crunchy Crunchy is offline
Crunchy's Avatar
...and what battlax is it ? Yes definitely go for the 180
Old 24-Sep-2005, 20:48   #4
rob748b's Avatar
Mood: happy dayz!!
I am running the battlax BT56, i live not too far from Cadwell so roads are nice twistys, i have just had the bike set up properly and find it alot easier to ride than i did, so i suppose it is for fast blasts, but do occasionaly got on long runs on it so i am a bit confused!!??
Rob
Old 24-Sep-2005, 21:01   #5
Diablo for fast road, Diablo Corsa for track day & fast road
Old 24-Sep-2005, 21:12   #6
Dibble
or, if you get on well with the Bridgestones go 012SS's .. they will do everything .... in the wet and dry .......
Old 24-Sep-2005, 21:14   #7
Gaz 748's Avatar
What chris.p said
Old 24-Sep-2005, 21:28   #8
748IOM 748IOM is offline
Mood: Yellow!!
BT014's get my vote. Good medium/hard compound in the middle with a soft/medium compound on the outer edge of the tyre. Will do everything you should need for road and trackday use.
If you're changing the tyre type/make/tread you should really change both tyres to prevent adverse effects to the handling.
Old 24-Sep-2005, 21:35   #9
Crunchy's Avatar
I'm with 748IOM. I've tried most road tyres and they are the best for me too. And don't forget to go to a 180 rear.
I don't think having two different makes of tyre make that much difference. I've often raced with a Michelin front and a bridgestone rear or vice verse
Old 24-Sep-2005, 22:17   #10
rob748b's Avatar
Mood: happy dayz!!
Thanks guys given me food for thought, will let you know how i get on
Rob
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:42.
