Old 25-Sep-2005, 10:08   #1
duck duck is offline
duck's Avatar
749s fueling mod
took my 04 749s in for it's first annual service yesterday and mentioned that it keeps cutting out at junctions/roundabouts etc sometimes with a pop from the exhaust. also that the throttle is like an on/off switch when trying to gently apply power mid corner which is unsettling the bike.
i was told this model has a defect and needs an ecu mod and possibly new throttle bodies all replaced under warranty but as the bike was purchased new at DK motorcycles (not a dealer) and therfore not an 'official' import they would not do it and it's up to DK to sort it out.
it will cost at least £600 to sort and if it needs throttle bodies god knows how much.
i'm not very happy as it's not even a component failure but a factory recognised defect which DK couldn't possibly sort out as they dont have the equipment.
has anyone had a similar fueling/dealer problem with an 04 749s?
Old 25-Sep-2005, 10:26   #2
Chippy alos experienced cutting out problems with his 749 from DK see the original thread here
http://www.ducatisportingclub.com/xm...4414#pid125091
Old 25-Sep-2005, 10:36   #3
HW HW is offline
Yikes, not heard that story before. 749's do suffer fuelling problems with slow running which is usually sorted out at first service. Mine was like that, kept cutting out just as I was about to pull out of a junction. I'm not aware that there are any differences between the 03 that I have and the 04 model, unless it is down to a batch of ECUs but then the throttle body thing makes no sense then.
Have you tried phoning a different dealer to see if they tell the same story? Try giving Craig at Italia in Lincoln a ring on 01522 888748 and ask what they know? I am confident you won't get any BS from them.
Old 25-Sep-2005, 10:54   #4
itexuk itexuk is offline
itexuk's Avatar
Mood: Great
Had / Have the same problem with mine, been in to dealer 3 times and is now alot better but will still stall now and again. No new parts were fitted, was told they had a new tool to help with set up.
Old 25-Sep-2005, 10:56   #5
duck's Avatar
my heads still a little scrambled from getting up so early to watch the gp.
so what you're saying skidlids is set it up for a 1999 Fiat Punto non-UK and adjust the butterfly screw by a 1/4 turn open? would a pc3/dyno cure it cos i'll probably go that route eventually just didnt want to yet.
yep, i was shocked at throttle bodies but thats what they said if the ecu didn't cure it. i'll give italia a bell on monday and see what they say.
Old 25-Sep-2005, 11:00   #6
duck's Avatar
itexuk is it an 04 model? cutting out is a pain but it's the on/off throttle mid corner thats making me a bit nervous
Old 25-Sep-2005, 11:05   #7
Carbon749's Avatar
Mood: I own a flame thrower
DUCK ............ you have been told a load of Bull about the warranty etc. It's just the dealer being awkward for the sake of it.
I had a problem with my 2003 749s which is an import. The dealer (who will remain nameless) identified that I needed new ECU and Clocks, but, would not do it under warranty as the Ducati computer showed my bike as being in a crate in Europe and not on the road in the UK. The dealer claimed it was Ducati UK that would not cover the warranty and not the dealer , he was trying to help me ?????
I phoned Ducati direct ready to give them a round of f***s on the phone, only to talk with a great guy who could not see what my (or the dealers) problem was. Ducati UK simply said that I had to have the bike PDI'd by an authorised Ducati dealer who would then register it on the Ducati UK computer system. All work after that was sorted under warranty. I did have to pay for the PDI which was about 2 hours labour.
Go back to your dealer and at worst case pay for a PDI ... AND NO MORE.
If you need any more help from some one who has been through the same please let me know.
Old 25-Sep-2005, 11:09   #8
itexuk's Avatar
Mood: Great
Yep 04 model 05 reg done 1800 miles. I do not have a problem with throttle mine is very smooth but it is very sensitive.
Old 25-Sep-2005, 11:24   #9
duck's Avatar
i emailed ducatiuk last night so i'll see what they have to say. i'll give them a phone as well and see if i can get the same response. i think theres no question they should do it as its a factory defect.
thanks for the offer of help if i need it
Old 25-Sep-2005, 11:26   #10
itexuk's Avatar
Mood: Great
http://www.moto-one.com.au/performance/duccamspec.html
refers to the revised cam timing specs for 749S ’04 models as detailed in service information re: stalling at idle. Simply changing the centreline settings for the cams to reduce overlap. It amazes me that such a small change in timing can have such a pronounced effect on how the bikes idle
[Edited on 25-9-2005 by itexuk]
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 13:52.
