Old 26-Sep-2005, 21:15   #1
richduc richduc is offline
Just a quicky!
Hi all
What is the front disc thickness on a 748R to start with - just trying to gauge how much wear I have left - I know its 4.0mm minimum.
Old 27-Sep-2005, 01:08   #2
Crunchy Crunchy is offline
Crunchy's Avatar
If you look at the disc mounts there should be a stamp that tells you the minimum thickness of the disc before you have to change them.
Old 27-Sep-2005, 01:29   #3
not sure but I think they may start out as 4.5mm, I have a couple of sets at home so easy enough to check sometime to see what mine currently are, not much wear on one set so should be a good indicator
Old 27-Sep-2005, 10:13   #4
4.5mm ............... wear limit of 4mm
